Anything else to tend to when replacing ball joints?
Old Oct 26, 2015 | 7:03 PM
2KBurb's Avatar
Default Anything else to tend to when replacing ball joints?
Hey guys, I just bought a 2k Suburban, I am replacing the ball joints and I was wandering if there was anything I may need to change for the heck of it while I am dirty?
Old Dec 28, 2024 | 10:49 AM
starman8tdc's Avatar
I would take it to Les Schwab and have them do a free inspection with a written quote. Then you have an itemized list of everything that could be replaced if you wanted everything to be perfect. They will list everything, including things that could last a while longer before being replaced, but that do show at least some level of wear.
Old Dec 28, 2024 | 11:16 AM
Get an alignment after you finish.
Old Dec 31, 2024 | 5:00 PM
Swan01's Avatar
A wheel alignment is not needed unless the tires or some other component were changed and an alignment was completed with a failing or failed ball joint.
Old Dec 31, 2024 | 5:01 PM
Swan01's Avatar
Since you are already there, I would recommend replacing stabilizer bar end links.
Old Dec 31, 2024 | 5:03 PM
You said you were replacing the ball joints.
Old Dec 31, 2024 | 8:14 PM
Swan01's Avatar
I am not the original poster on this post.
crystallee3
Oct 18, 2013 10:05 AM
Outlander 2004
Oct 17, 2012 9:31 PM
Coder1
Dec 3, 2011 10:10 PM
BigDaddyO
Oct 18, 2011 11:09 AM
Mr.Cale
Feb 7, 2010 7:07 PM
