Auto Trans. floor shifter conversion
Old Jul 2, 2011 | 4:38 PM
white bear's Avatar
Default Auto Trans. floor shifter conversion
Of the two Lokar and B&M, which do you consider the best and why.
Old Jul 3, 2011 | 2:20 PM
phord's Avatar
Default auto trans,floor shifter conversion
It depends on what kind of car its going in. For a street rod, I think I'd go Lokar.They've got more styles for that genre.Thay are REAL pricey,but good quality. As for any other advice, I find them to be "stuffed shirts".
For a muscle car, go B&M. Ther stuff seems beefier, and more geared to muscle. I also find them more personable and much more eager to help you in other directions if they haven't got what you're looking for.
Both will definately get the job done
Old Jul 4, 2011 | 6:26 AM
white bear's Avatar
Thanks for the reply. Actually the install will be in a Colorado. Does one install easier than the other. Do they both lock into gears the same and have the same feel. Ken
Old Jul 5, 2011 | 11:02 PM
phord's Avatar
From what I remember, Lokar actually mounts the shifter mechanism to the trans case (below the floorpan)whereas the B&M usually mounts to the tunnel(inside the interior). I would guess after looking at them, that the B&M would be easier to mount just cause you don't have to cut a big hole in the tunnel for the shifter. B&M also makes a "universal" pan mounted bracket which makes it a snap to hook up. Their actual shift arm is really sloppy on a 700r4 and that can make adjusting a pain. I believe the Lokar uses a rod to connect.
A question to consider is whether or not you are using a center console. If you are, the lokar would be a pain.Don't get me wrong, the Lokar is a really nice product( I hate to say that - their customer service sucks)
I would suggest you talk to somebody at Jegs or Summit for more onfo. Of course you can also call Lokar or B&M, but their advice would be biased.
Good luck.
johnmcgrady35
May 26, 2021 12:34 AM
86k5
K5 Blazer
Jun 21, 2010 10:13 AM
squarepeg
Apr 8, 2010 7:18 PM
Speedy650
Jan 30, 2010 10:46 PM
