backfire when i deceleration.
Old Oct 28, 2008 | 9:12 AM
justchilln1424's Avatar
Default backfire when i deceleration.
What cause backfire when i deceleration or downshift? Its not my timing i've check already. Can it be my vacuum advance??? I got a 1962 chevy impala 283 v8 hei distrubutor, wt glass pack exhaust systems. which basicly mean straight pipe.
Old Oct 28, 2008 | 9:49 AM
budsjlm's Avatar
Default RE: backfire when i deceleration.
help to know what ya got
Old Oct 28, 2008 | 1:04 PM
74chevy4life's Avatar
make model year and type of motor would be very helpful
Old Oct 29, 2008 | 5:15 PM
Chuzz's Avatar
Could be a clogged catalytic converter.
Old Nov 1, 2008 | 2:32 PM
therewolf's Avatar
Insufficient back pressure,(usually an exhaust leak) will cause a backfire. If the exhaust is changed radically from stock and there's an absence of normal back-pressure, you could also get a backfire. Assuming you've got a high-mileage engine, worn valve-train components, such as a worn-out cam or very warped or leaky valves could cause a backfire. A bad exhaust, if unfixed, could ruin your cam and valve train by causing excessive backfiring. Is your crankshaft damper aligned properly?(They slip sometimes, leaving the timing mark out of sync) Check your distributor, be sure the rotor is aces, if it's loose or defective,-backfire! Are your engine specs true for the engine you're actually tuning?Be sure, because if you're setting the timing wrong, you're also tuning other specs wrong.
Old Nov 7, 2008 | 1:42 PM
budsjlm's Avatar
did ya ever think you practically have strait pipes your back pressure is down try gettimg new exhaust even when you go to a parts store and has the little box with the diff sounding exhaust reving you can clearly hear backfiring after it is reved with a glass pack its more or less a charcteristic of the muffler
frederick1010
Nov 26, 2018 4:33 PM
jimmyjames13
Mar 21, 2015 9:26 AM
philip.camp
Oct 13, 2011 11:10 AM
