bad pump or worn bearings
Old Dec 11, 2013 | 10:17 PM
trav502's Avatar
Default bad pump or worn bearings
just bought a used/rebuilt engine for my truck. Bottom end is used unsure of miles. the oil pump is supposed to be new, when i start the truck it carries 50psi then gradually falls off to 5-7 psi when it comes up to temp. oil is new 10w-40 pennzoil, with a Bosch filter. Im going to change the pump. So should i change the bearings while im in their and also should i put a high volume pump in. The engine is built some and will be ran hard, just trying to get someone else's opinion
Chev_Hoe
Jan 14, 2014 9:41 PM
zbkeebler
May 3, 2013 1:28 PM
BWS
Astro
Jan 21, 2011 7:22 AM
brewsterbaker
May 24, 2008 2:03 PM
454 dually
Aug 31, 2006 10:43 AM
