Battery light on dash
Old Jan 13, 2023 | 10:45 PM
Ohthree2500hd6.0's Avatar
Default Battery light on dash
I've had the light on for 3 days I replaced the battery the alternate as well and it's still on even when the truck is off with the key out. Does anyone have an idea at what can be the issue?
Old Jan 14, 2023 | 9:57 AM
Rednucleus's Avatar
Starting ok? What does the dash meter show for volts when running? Have you checked battery/atlernator with meter? I assume light stays on when running?
Old Jan 14, 2023 | 12:35 PM
Default Feedback
When you say dash meter you mean the battery indicator? No I haven't checked the battery or alternator I replaced both they are new. And yes the battery light light indicator stays on at all times even when the truck is off. I've checked all my grounds and everything seems good. So idk what it can be. Thanks for the feed back.
Old Jan 14, 2023 | 1:31 PM
Rednucleus's Avatar
Yeah just curious your dash voltage reading vs if you check with a meter at the battery
Old Jan 14, 2023 | 2:58 PM
I haven checked it , that's what I will do next.whats a normal reading?​​​​​
Old Jan 14, 2023 | 3:21 PM
kevinkpk's Avatar
Around 14vdc.
Jiyu
Oct 29, 2020 7:32 AM
dmikitka
Mar 15, 2015 9:58 AM
Dave304
Feb 8, 2015 6:16 AM
vbwannabe13
Mar 27, 2013 9:25 AM
07Tahoe1234
Sep 19, 2011 5:57 PM
