blower motor
Old Aug 8, 2018 | 9:39 AM
Charles Shaheen's Avatar
Default blower motor
Specs
2008
chevy
cobalt
4 door
2.2 litter
problem
on my motor blower the pig tale went bad(burnt) so I replaced it with a new one and now it doesn’t work at all the wires are hooked up correctly but just won’t blow I checked the fuses they r good not sure if there is a fuse for it under the hood or not but idk how to check the relay that’s in the interior fuse box
question 1: does any one know how to check that relay?
question 2: what else could be wrong with the blower motor?
the ac kicks on because when I turn the switch on the compressor kicks on please help thanx
the 1st pic is the new pig take and the blower motor and the 2nd pic of the under hood fuse box
Last edited by Charles Shaheen; Aug 8, 2018 at 9:42 AM. Reason: Wrong picture added
Old Aug 8, 2018 | 2:08 PM
kevinkpk's Avatar
Swap the relay with another one, I think those are all the same.
Old Aug 8, 2018 | 5:20 PM
“Update”
i swapped the fuses under the hood for 2 other ones and it blows but it barely blows anything out I checked the cabin filter and it’s fine
Old Aug 9, 2018 | 7:55 AM
Possibly the blower motor resistor. Try putting 12 volts to the blower motor directly to see if it runs at full speed.
Old Aug 9, 2018 | 9:48 AM
“SOLVED”
I had the pig tale wires backwards ty all for the help
