Boat question...I'm completely lost
Old Jul 24, 2008 | 4:54 PM
  #11
jkgray80's Avatar
Default RE: Boat question
Wouldnt hurt. You can have good compression w/incorrect timing though.
Old Jul 24, 2008 | 4:55 PM
  #12
jkgray80's Avatar
Just at wrong time. An advanced distributor never cured,,,
Old Jul 24, 2008 | 4:57 PM
  #13
jkgray80's Avatar
Dont know if my post are even going through now,,ill get back to you
Old Jul 24, 2008 | 5:00 PM
  #14
jkgray80's Avatar
ORIGINAL: jkgray80
worn valves or rings for me.
Old Aug 6, 2008 | 4:04 PM
  #15
metal249's Avatar
I put on new coil, pertronix electronic igniton, and new plug wires. I checked TDC on the number one cylinder and the mark is correct. Runs much better. I set the timing and tuned it up (5 degress above TDC, idle at 550rpm), but when I give it a little rev, it stays at 2000rpm for a few seconds, before slowly dropping down to about 1000 rpm. I recheck the timing and it jumped up to 20 degrees above TDC. I also put a fuel pressure gauge on it. It reads 3.5 psi at 1000rpm and 3.5 to 4 psi at 2000rpm. Is my pump bad?
Old Aug 10, 2008 | 4:09 PM
  #16
metal249's Avatar
Just did a vacuum test off the carb. 10 inches at 1000rpm and 15 inches at 2000rpm. I think that is about right. I also think that eliminates a misaligned timing chain as the problem.
[/align]
Old Aug 10, 2008 | 8:11 PM
  #17
metal249's Avatar
I just did a compression test.
1. 115psi
2. 105psi
3. 105psi
4. 105psi
I don't know what these numbers are supposed to be, but they are all pretty even.
jeff6898
Aug 7, 2008 12:27 PM
GIXXER
May 2, 2008 8:06 AM
cographix
Dec 22, 2007 10:16 PM
haidangwa
Jun 28, 2007 10:27 AM
