Botched crankshaft install need help
Old Jan 17, 2017 | 3:16 PM
Ypsik10's Avatar
New User
Awaiting E-mail Confirmation
Default Botched crankshaft install need help
Installed newly cut crankshaft in my 74 350 2 bolt block will not rotate or spin freely ... Is this due to puttin oil between main bearings and block?😳
Old Jan 17, 2017 | 4:44 PM
kevinkpk's Avatar
Did you put lubriplate (ex) on the bearings when installing?
Old Jan 17, 2017 | 6:18 PM
Ypsik10's Avatar
New User
​​​​​​​no I did not
Old Jan 18, 2017 | 9:29 AM
Are you using the correct size main bearings?
Old Jan 18, 2017 | 3:09 PM
kevinkpk's Avatar
If you have access to an anvil micrometer, and telescoping gauge, you need to check the clearance, and when you determine if it is good, lubriplate the bearing journals when putting it back together.
