Brakes?
Gotta problem, I need HELP!
My 01 2500hd has a brake issue. My ABS and brake light came on awhile back. Soon after that I pressed the pedal extremely hard. The pedal went to the floor!!! I replaced the master cylinder and blead the lines twice. THe pedal STILL can be pressed to the floor. Any idea why???
If your brake pedal goes to the floor then you definitely have a problem. If it were an older car, the brake master cylinder ora leaking system (a puddle of fluid under the carwillcertainly indicatea leaky system) might be the cause. Because it's not an old car I would think about properly bleeding the system. If it still goes to the floor I would have it looked at by a trained mechanic, you don't want tofiddle aroundwith your braking system unless you have the technical know-how.
_____________________________
Satified Chevrolet Trailblazer owner
JRich_taco
Aug 31, 2013 12:16 AM
Mille Racer 69
Dec 8, 2010 8:26 PM
