A.c. compressor runs at all times
Old May 9, 2017 | 8:24 PM
Nagrom88's Avatar
Default A.c. compressor runs at all times
I have a 98 silverado extended cab my a.c. compressor runs all the time I changed out my hvac control an nothing has fixed the issue. Any help would be aappreciated thanks
Old May 10, 2017 | 8:38 AM
Disconnect the power to the compressor and see if it still runs. If it still does run then the clutch is bad. If it stops then it is a short somewhere in the wiring.
Old May 10, 2017 | 12:22 PM
Nagrom88's Avatar
When I unplug power to the compressor compressor doesn't run. I even tried swapping relays didn't work. The system is low on refrigerant because it doesn't cook at all.
