a/c recharge
Old Mar 29, 2007 | 8:33 PM
gjd99tahoe's Avatar
Default a/c recharge
I have a 99 Tahoe it has a rear a/c control when turned on it is cooler than the front i know the front needs to be charged will it effect the rear a/c or not.
Old Apr 16, 2007 | 11:58 PM
48fan's Avatar
Default RE: a/c recharge
The front and rear are part of the same system; you can't charge one or the other. However they do have separate evaporators. Poor cooling can be caused by a number of things: Restricted Condenser or discharge hose, restricted receiver/dryer, Expansion valve/orifice tube plugged, Defective compressor (not in your case), System overcharged w/ refrigerant, Defective fan clutch (only at low vehicle speeds).
As you can see it can be a number of possibilities, so before you go putting more refrigerant in the system I would get some manifold gauges to check your head pressures. If you don't know what your doing have a professional check it because you can wind up screwing up your whole system and costing yourself a lot of money.
jhplove737
Jul 18, 2008 3:03 PM
rjsasaoka
Jun 28, 2008 9:39 AM
STiYLIN
Jun 7, 2007 1:06 PM
Mike E
Aug 19, 2006 12:48 AM
jmastera
Jul 26, 2006 3:00 PM
