Camshaft play 350
Old Nov 22, 2020 | 3:36 PM
Pilotpat's Avatar
Default Camshaft play 350
I'm asseblying my fisrt motor, Gen 1 small block. I have the cam and timing set installed and was degreeing. I'm noticeing that the camshaft lobs are shifted to the rear of the lifter bores. Without the distributor installed I have around 1/4 to 3/8 play in the camshaft front to back with the chain installed. I know the lifters pull the cam towards the back of the motor but how much is normal.
Q: Does the distributor help center the camshaft in the bores when it is installed?
Old Nov 22, 2020 | 3:52 PM
kevinkpk's Avatar
Nope. You should have about .003" lift on the cam shaft to bearing the distributor will not make any difference.
Old Nov 22, 2020 | 3:55 PM
kevinkpk's Avatar
You are probably ok with the thrust.
Old Nov 22, 2020 | 3:59 PM
Pilotpat's Avatar
Thanks both for the quick replys.
Next question I guess is that are the lobes location towards the back of the bores normal? I pretty sure the crank sprocket is on fully and regardless the cam is against the thrust surface of the block when I'm noticing this condition.
Old Nov 22, 2020 | 4:38 PM
kevinkpk's Avatar
Cam lobes are going to be aligned with the crank shaft. You will have to align the big gear (cam) to the small gear. Will be a mark to align them, make sure you have them correct. You can google this for reference.
Old Nov 22, 2020 | 5:44 PM
Pilotpat's Avatar
Rgr that and thanks.
streetrod
Mar 30, 2018 4:50 PM
jonathan_l_b
Dec 25, 2013 6:16 AM
eturner
Apr 16, 2012 3:41 PM
bowtietwist
Apr 1, 2012 8:12 PM
roman316
Dec 18, 2006 3:15 AM
