Old Jul 22, 2015, 10:59 AM
How-Tos on this Topic
Last edit by: IB Advertising
Print Wikipost
can I add an inline fuel pump instead of replacing the pump in the tank?
Old Dec 13, 2007 | 9:07 PM
22charlie's Avatar
Default can I add an inline fuel pump instead of replacing the pump in the tank?
It would be easier and cheaper to add an inline pump. Does anyone know if that would work?
Old Dec 14, 2007 | 5:55 AM
astroDZak's Avatar
Default RE: can I add an inline fuel pump instead of replacing the pump in the tank?
Most newer cars require more pressure than the average inline fuel pump can deliver. Also finding a safe place to mount the pump isnt usually all that easy.
Pricewise since I don't know what your car is would be impossible to guess but in most cases there wouldn't be enough difference to warrant the extra work with wiring and mounting an external pump.
Old Dec 14, 2007 | 8:13 PM
22charlie's Avatar
It is a 99 suburban with the 42 gallon tank. Finding a safe place for the pump would not be a problem but I don't know about the pressure needed.
Old Dec 14, 2007 | 9:58 PM
EvansBlue's Avatar
It WILL NOT be cheaper to go inline. Theres custom modification that would have to be done, and that costs $$$.
You'll need the greater pressures with the 5.7L. If you externalize the fuel pump and get a high pressure fuel pump,it will work with custom modifications to the tank, but the noise will drive you nuts.
Old Dec 14, 2007 | 10:14 PM
22charlie's Avatar
Do you know what the "custom modifications" are. I can get a high pressure pump for $100 that alot cheaper than a good intank pump.
Old Dec 15, 2007 | 5:33 AM
astroDZak's Avatar
I don't understand. If an inline pump is 100$ and you have to make it mount and hook up how much are they trying to rape you for the original equipment pump?
In October I put a new pump into a 99 3/4 ton 4x4 pick up. The pump was $54 and I bought the filter sock with it for $9 plus tax still was a long ways from $100.
They put the pumps in the tank now for safety reasons (not enough oxygen inside the tank for fire or explosion) I think I would stick with it myself.
Old Dec 15, 2007 | 9:09 AM
22charlie's Avatar
I put a new $160 pump in the tank two years ago. If I had bought the $300 one I probably would not have this problem. I put it in myself took about 4 hours and it was a pain in the as. If anyone has cheaper and easy way to do this I would be happy to here it. Thanks
Old Dec 15, 2007 | 9:27 AM
Dirtsurfer's Avatar
I remember the first time I did an in tank fuel pump on my truck, onthe floor and countless hours. The next time it went out, I cut a hole in the floor of the bed and rtv-ed a patch down afterwards (have a carpet bedliner over). Nowit can be done in ten minutes and no more rust in the eyes.
Old Dec 15, 2007 | 10:01 AM
EvansBlue's Avatar
It was noisy wasn't it?
Old Dec 15, 2007 | 5:49 PM
cplthomas's Avatar
Do you plan on deleting the oem pump? since you are going to be there you may as well just replace it. What is the cause for the replacement anyways? 2 years is too often to replace a pump. In addition to an inline pump you will need a fuel preassure regulator.
