Can I disable the honk when I exit the car with fob?
Old Oct 12, 2016 | 9:24 AM
Jeff Bellamy's Avatar
Default Can I disable the honk when I exit the car with fob?
Hi everyone!
I have a 2016 Chev Impala LTZ and when the car is running if I exit the vehicle and close the door with the fob on my pocket, it honks 3 times. Is there anyway to disable this function?
Thanks!
Old Oct 16, 2016 | 4:02 PM
autowiz's Avatar
I am pretty sure you will change these settings with buttons on your steering wheel or side of your instrument panel and I am quite certain you will find instructions for passive arming settings in your owner's manual
Old Oct 17, 2016 | 1:05 AM
Nav613's Avatar
The system is reminding you that the ENGINE is running, and you are leaving it that way.
"IF" you have already disabled the HORN on arming, and dis-arming the locking system,
You may NOT be able to do this. HOWEVER it may turn into chimes, instead of HORN,
"IF" your lucky. Happy Motoring
