Can someone help me find the right coolant temperature sensor for 4.3L?
Old Jul 9, 2015 | 12:30 PM
JonDick13926's Avatar
New User
Awaiting E-mail Confirmation
Default Can someone help me find the right coolant temperature sensor for 4.3L?
My grandpa bought a very well preserved 1992 s10 the other day. The coolant temp gauge does not work (as in it always sits on zero degrees), I did standard test of grounding the green single wire and watching the gauge jump to high, and drop back down when I removed ground.
The plug is the same as the other temp sensor for the ecu, but with one terminal instead of two. I've tried looking online at the parts stores and at acdelco, but never found anything that specifically said "one terminal", and the only pictures I saw showed either two vertical terminals or one vertical and one horizontal terminal. I went to Napa today and the only thing they said they had was a two terminal version.
Does anyone know for sure what the acdelco or Napa Echlin part number is for this sensor with ONE terminal?
Kodiak
Dec 5, 2013 9:11 AM
Kodiak
Dec 5, 2013 12:52 AM
tom5170
Feb 6, 2011 10:27 PM
2000Impalaspeeder
Camaro
Aug 3, 2010 10:06 AM
mazdacaddi
Feb 16, 2007 5:03 PM
