Can you add a towing package?
Old Dec 16, 2009 | 9:00 PM
trad748's Avatar
Default Can you add a towing package?
I am interested in buying a pop up trailer that weighs 1800 pounds. I have a 2004 Chevrolet Venture. In the manual it says I can only pull 1400 pounds with up to 5 people. Although it says if you have the optional trailer towing package you can tow up to 2900 pounds. I do not have the this towing package. Can it be added?
Any help would be greatly appreciated.
Old Dec 16, 2009 | 9:06 PM
nauticstar87's Avatar
Many tow packages consist of lower gear ratios, different geared transmission, the tow/haul button. It's a lot more then the hitch on the back. I don't exactly know what would need to be changed in a Venture though. In other words, if it can be done, it'd be expensive.
Old Dec 16, 2009 | 10:05 PM
Bill's Dad's Avatar
usually at least a transmission cooler and extra duty radiator. You should be fine...just drive easy and mindful. I had a 95' APV w/3800, 100,000miles and fresh trans.rebuild in which 1 summer, I use to tow my nephews 3500lb. boat back and forth to a local Lake and even pulled that baby up the launch!!! no problem. throw a hitch on it, change trans oil and flush radiator, have good tires and brakes and go for it..you're only talking 500lbs more..a couple people...
Old Jan 31, 2010 | 1:00 AM
timmysouthpark's Avatar
Is it front wheel drive?
Weights: gross vehicle weight rating (lbs) 5,357, curb weight (lbs) 4,431, gross trailer weight braked (lbs) 2,000 and max payload (lbs) 1,457
Front wheel drive vehicles will jack knife on gravel/sand/snow or ice with a trailer. On dry pavement it shouldn't be a problem. "usually at least a transmission cooler and extra duty radiator."
Trailer brakes would be a plus !
I towed a Prius 500 miles with a Prius on a 2 wheel dolly. Jack knifed it twice on loose gravel on paved streets... Not very safe.
cupandbook
Camaro
Jun 5, 2014 10:36 AM
D-Train
Mar 28, 2012 7:47 AM
Nyron
Jun 28, 2010 10:55 AM
ChevyguyArmen
Apr 30, 2010 7:03 PM
6pac
Nov 29, 2007 5:25 PM
