Can't remove the tail light to change bulbs
Old May 26, 2018 | 4:56 PM
trailbreaker's Avatar
Default Can't remove the tail light to change bulbs
someone must of torked them down tight... tried phillips screw driver and electric drill and nothing i'm afraid i'll strip the screws, or do i need to take it to a dealership
Old May 26, 2018 | 5:50 PM
Rednucleus's Avatar
please post year model etc for help
Old May 26, 2018 | 5:52 PM
2003 chevy trailblazer
Old May 27, 2018 | 1:15 PM
can anyone help
Old May 27, 2018 | 4:04 PM
You don't have much choice. If a phillips screwdriver fits in tight, force it as much as it takes to loosen the screws. If that fails then try some speedouts. That should work.
Old May 27, 2018 | 4:44 PM
i did that the screw driver would just come off... i'll see if my neighbor has one
Old May 27, 2018 | 6:17 PM
Rednucleus's Avatar
maybe a little pb blaster and let it sit overnight?
Old May 27, 2018 | 10:00 PM
I used WD-40
Old May 29, 2018 | 1:27 PM
SBchevyfan's Avatar
If you do too much damage to the head of the screw you can also try a couple other things. First, use a die-grinder / cut off wheel and just cut a straight slot in the screw and try a flat bladed screwdriver. Second, drill the screw out and install a larger screw when replacing the lamp.
Old May 29, 2018 | 1:37 PM
kevinkpk's Avatar
If you damage the head, and can get it out a little bit, use a pair of side cutters underneath the head, and unscrew it.
