Carb backfire
Old Jun 6, 2022 | 9:14 PM
Schlegs's Avatar
Default Carb backfire
Hello all. I’m looking for help because I’m lost. I just bought a 1977 K5 Blazer 350 engine. It had some fouled plugs, which I replaced, and a leaking valve cover gasket. When changing the valve cover gasket I noticed the #7 intake rocker arm was loose. It has roller rockers. I followed the steps and adjusted the rocker arm. Fired it up and it drove great. After about 20 miles, it started backfiring out of the carb out of nowhere. I found a small vacuum leak on a cap on the carb. Replaced the cap and it’s no better. I don’t hear or see any other leaks. I checked the rocker and it’s still snug. It only backfires once per rotation leading me to think i have an issue in one cylinder. Any suggestions would be great.
Old Jun 7, 2022 | 12:35 AM
oilcanhenry's Avatar
I'd do a dry and wet cylinder compression test, were I you. It's an old engine, so it would be a good start.
No shadow
Mar 19, 2021 3:47 PM
wraith9000
K5 Blazer
Dec 31, 2013 3:24 AM
budsjlm
Feb 15, 2011 2:32 PM
Mike767
Jun 15, 2009 9:59 PM
