Carburated to fuel injection
Old Mar 22, 2013 | 12:17 PM
BigSteve's Avatar
Default Carburated to fuel injection
I took a 79 carburated motor out of my blazer and replaced it with a complete, good running fuel injected 88 chevy motor out of a pick up. The computer and the fuel pump are matched to the motor. The wireing harness to make the TBI work is after market, did away with egr valve and other smog equiptment including smog pump. Some of the smog equipment is still in tact, such as map sensor, the knock sensor and temp sensor.
Now that the blazer is finaly put back together, ive started it and it will not idle correctly and dies after it warms up. My spark plugs are getting dirty very quickly and it seems like my cylindars might be filling up with fuel. The timing should be right, all the wiring seems to be right and I am pulling my hair out trying to figure out why its not running correctly. Can someone PLEASE help me?
Old Mar 22, 2013 | 2:10 PM
kevinkpk's Avatar
I'd suggest you check wiring connections, especially at the map sensor. That has to be correct or your fuel/air ratio will be off. Thats what it looks to me based your post.
Old Mar 22, 2013 | 3:33 PM
BigSteve's Avatar
Thank you Kevin, you are the second person to suggest the MAP sensor, I will definately check it!
Old Mar 26, 2013 | 12:30 PM
BigSteve's Avatar
Kevin, I just wanted to thank you again. Checked the MAP sensor and it was not properly cpnnected. Blazer is running great now!
Old Mar 26, 2013 | 12:54 PM
kevinkpk's Avatar
Thanks for responding back.
einstein2nd
Sep 27, 2007 5:38 PM
Aphelion79
Jan 6, 2007 11:16 PM
rich
Mar 28, 2006 6:55 PM
