Check engine light / oil preasure ?
Old Dec 30, 2023 | 2:43 PM
kmny's Avatar
Default Check engine light / oil preasure ? 2012 silverado 157,000 miles
Any one see this before? Sensor?
Old Dec 30, 2023 | 2:56 PM
It could be the sensor. It could be the screen under the sensor needs cleaning. It could be too low on oil. It could be the engine is worn out. You don't say the age of the engine or the mileage on it.
Old Dec 30, 2023 | 3:09 PM
kmny's Avatar
2012 157,000 miles
Old Dec 31, 2023 | 10:29 AM
The real question is if the proper maintenance was done at the correct times. Oil and filter changes are super important and need to be done at the proper intervals.
Old Dec 31, 2023 | 1:13 PM
Rednucleus's Avatar
Is there an oil pressure guage on the dash - what does it read?
Old Dec 31, 2023 | 3:37 PM
kmny's Avatar
digital like pic shows dashes normal should have number of psi
Old Dec 31, 2023 | 5:22 PM
Did you run a diagnostic scan to see why the CEL is on?
Old Jan 14, 2024 | 2:04 PM
kmny's Avatar
Po521 and po523 codes
Old Jan 14, 2024 | 4:44 PM
Follow all these "diagnostic and repair steps":
https://www.obd-codes.com/p0521
https://www.obd-codes.com/p0523
Mihai061980
Cruze
Mar 7, 2023 10:05 AM
prostreetpop
May 1, 2022 11:48 AM
L84sky
Oct 22, 2020 6:07 PM
101btp
Nov 30, 2010 8:36 PM
