Chevelle help
Old Sep 22, 2015 | 12:42 PM
chevelle 69's Avatar
Default Chevelle help
I have a 69 Chevelle with a 74 to 78 350, not sure exactly. I just replaced the timing chain and got everything lined up, it's getting spark and gas maybe too much gas. It still won't start, I'm at a loss. The plugs, distributor cap and rotor are all new. It turns over just fine. I'm looking for some ideas. It's possible the timing is still off but I don't think it's that far off.
Old Sep 23, 2015 | 5:55 PM
old dog's Avatar
run through all the timing set up.pull ! plug and roll it over to the compression stroke on number 1 cylinder and see what cylinder it is pointed at on the distributer you may be 180 degree's out ,or a couple teeth on the distrubuter gear .when you reinstalled the distributer assuming th timing gears are lined up .
amdavis15
Chevelle & El Camino
Jan 27, 2016 11:21 AM
FiretoFlames
May 13, 2012 6:36 PM
Anthony92
Feb 7, 2011 8:15 PM
RATMAN
Sep 1, 2006 12:32 AM
Medic2891
Aug 30, 2006 11:46 PM
