Chevy brakes
Old Jan 26, 2021 | 10:57 AM
Buck Powers's Avatar
Default Chevy brakes
Need to replace booster and master cylinder, No code number on parts sticker . 83 Suburban, 2WD, auto, 350, Replacements say JD5 or JB7 but how do I find out which is correct?
Old Jan 26, 2021 | 11:13 AM
With the vin number the dealer should be able to tell which one it takes.
Old Jan 26, 2021 | 2:30 PM
oilcanhenry's Avatar
AC Delco 18M217 Master cylinder as to your B-B
Should be in your glove box, but here are the numbers:
JB5 BRAKE POWER, DISC/DRUM, 6,400 LBS
JB6 BRAKE POWER, DISC/DRUM, 7,200 LBS
JB7 BRAKE POWER, DISC/DRUM, 8,400 LBS
JB8 BRAKE POWER, DISC/DRUM, 10,000 LBS
Similarly, here's the list of brake systems that used the hydroboost:
JD5 BRAKE DUAL POWER, DISC/DRUM, 6,400 LBS
JD6 BRAKE HYD POWER, DISC/DRUM, 7,200 LBS
JD7 BRAKE HYD POWER, DISC/DRUM, 8,400 LBS
jbander
Chevelle & El Camino
11
Jul 17, 2021 3:52 PM
czh
1988 - 1998 (GMT400)
Apr 13, 2020 10:19 AM
marcin182ful
Feb 10, 2018 10:19 AM
wt189bricks
Oct 10, 2011 11:14 AM
steph66
Jun 10, 2009 10:38 AM
