Chevy K1500 97 Fuel pump failure...again...
Old Jan 20, 2014 | 9:41 AM
papesta's Avatar
Default Chevy K1500 97 Fuel pump failure...again...
Hi !
For the 4th time in 3 months, I've to change a failed fuel pump on my 1997 K1500.... Why ???
I'm linving in Switzerland where nobody know this Chevy Model.
Thanks for any help
Papesta
Old Jan 22, 2014 | 9:50 AM
Richardx2's Avatar
Is the failure electrical or mechanical? Have you checked the relay and wiring to the pump? Water or trash in the fuel? How does the filter look? If the filter is full of trash then the pump won't be able to operate correctly. A bit information about the failure is needed.
Old Jan 23, 2014 | 7:11 AM
papesta's Avatar
Hi Richard,
The failure is electrical. The pump fail after a month. No trash or water in the tank neither in the fuel line. The fuel filter was changed each time after the pump failure. All filters were clean. I did not check the relay or the wiring. By the way I do not have the wiring diagram. My Pickup was directly imported from the Canada to Switzerland a few years ago and this model is very exotic in my country :-)
It seems that the available pump model in Europe is not very reliable...
What about the fuel pressure regulator ? Does it have something to do with the failure ?
Thanks for looking on my Post.
Old Jan 23, 2014 | 11:06 AM
Next time make sure to replace the pump with a Delco or Delphi brand pump even if you have to import it from the US. Do not go with the cheap after market pumps.
Old Jan 24, 2014 | 2:01 PM
papesta's Avatar
Thanks for your help guys !
Any good web adress to order US pump ?
Old Jan 25, 2014 | 10:08 AM
RockAuto Parts Catalog
mangomanj
Aug 17, 2014 9:51 PM
BRB
Dec 28, 2012 8:34 PM
Redd Dogg
May 9, 2012 6:31 PM
hunter10220
May 18, 2011 8:37 PM
Richard
Jul 22, 2009 8:28 AM
