Chevy pickup
Old Oct 14, 2022 | 11:37 AM
jbuck5603's Avatar
Talking Chevy pickup
I Have a 1995 chevy 2500 picKup 4x4 with LT 245/75R26 tires. 5.7 liter what the rpm. supposed to be at 75 per hour
Old Oct 14, 2022 | 5:39 PM
oilcanhenry's Avatar
Just keep your tires inflated properly. I don't know what RPM it will be at 75 MPH. Some states, like Nevada allow 80 MPH, but with gas prices being high, the lower you drive, the better your MPG will be.
If you have cruise control, I would use it, as you'll get the best gas mileage using it. I wish had it on my 98' Chevy K-1500, as I have a lead foot I have to control, but it's been a great Chevy pickup truck.
Old Oct 15, 2022 | 12:30 PM
jbuck5603's Avatar
Talking oilcanhenry
thank for your reply. the reson i ask about RPM,s i just put new shift sensors in the trans, they seem to shift ok. but needed to know the rpm,s are correct, for the speed.. ty
Old Oct 15, 2022 | 6:30 PM
Gumby22's Avatar
To properly answer your question, we’d need to know what transmission and differential is in your truck. RPM’s will vary depending on if the transmission is a 4 or 5 speed and the gear ratio in the rear diff.
Check the RPO sticker in the glove box to determine the options you have.
Old Oct 16, 2022 | 9:06 AM
jbuck5603's Avatar
Talking
[QUOTE=Gumby22;483447]To properly answer your question, we’d need to know what transmission and differential is in your truck. RPM’s will vary depending on if the transmission is a 4 or 5 speed and the gear ratio in the rear diff.
Check the RPO sticker in the glove box to determine the options you have. GUWR-----8600/3901 GAWR FRT-------4250/1928 GAWR RR 6000/2722 LB/KS...... LT245/75R16E TIRES 5.7 LITER
Old Oct 17, 2022 | 7:29 AM
Gumby22's Avatar
[QUOTE=jbuck5603;483461]
Those are the axle weight ratings - it’s the gear ratio that needs to be known.
The sticker you’re looking for will have a bunch of 3 digit codes on it.
The gear ratio codes will start with a G or H and the transmission code will start with M.
Shelly Hewett
Dec 7, 2017 1:21 PM
Art61
1988 - 1998 (GMT400)
Jun 13, 2017 10:22 PM
Papa_Smurff
Mar 20, 2014 6:09 PM
crissjmz
Mar 12, 2014 11:31 AM
alarum
Jul 17, 2013 10:24 PM
