converters
Old Jan 21, 2008 | 12:38 PM
kb4422's Avatar
Default converters
can you take the catalytic converters off on a 2003 2500 6.0L? if you do, what problems will you all have?
Old Jan 21, 2008 | 4:43 PM
John86's Avatar
Default RE: converters
it will throw a o2 sensor code because thats where they screw in. other than that it shouldn't hurt nething.
Old Jan 21, 2008 | 9:58 PM
shawnvw's Avatar
Banned
I don't know what the emmision laws are like where you are at but here in Ontario Canada, removing the converter will not onlyget you a fine and your car impounded if caught, it will cause your vehicle to be a polluting pig so it won't pass an emissions test thus preventing you from renewing your registration
Old Jan 21, 2008 | 11:20 PM
kb4422's Avatar
will throwing an 02 sensor code hurt anything? or cause anything?
Old Jan 22, 2008 | 6:51 AM
John86's Avatar
yea unless u get some simulators. u will be getting a fulse fuel air mixture because it will not be bolted into the exhaust. it will prolly tell ur computer that u need more fuel since it will show to much air. so ur mileage will prolly go down. u can get simulators from summit or jegs. u'll be alright here in oklahoma they really don't care much. every truck that i have owned had straight pipes.
Old Jan 22, 2008 | 2:39 PM
ehhget's Avatar
The problem is that you will be polluting recklesly- you should not even condsider doing something like that - we all have an obligation to be resposnible.
Old Mar 27, 2008 | 12:42 AM
thomatt12's Avatar
Banned
Isn't it that the catalytic converter restricts the exhaust flow so it means taking it off will maximize the ride's potential. But that is in exchange of air pollution.
__________________
Where do you usually get your Jeep parts?
Old Mar 27, 2008 | 11:37 PM
mitchell03's Avatar
You will also lose low end torque because the converter causes back pressure and thats what helps the low end power all you will gain is sound.
Old Apr 2, 2008 | 2:42 AM
thomatt12's Avatar
Banned
ORIGINAL: mitchell03
I see, so removing the catalytic converter doesn't necessarily mean improved performance. I thought if you remove it it will result to better exhaust flow. Thanks for the correction.
__________________
Check out my Ford Focus Parts and Ford Taurus Parts for sale. Coolness!
kb4422
Jan 21, 2008 12:40 PM
sellersoasis
Jan 3, 2008 4:30 PM
sellersoasis
Aug 4, 2007 8:41 PM
BlackBeauty
Jun 22, 2007 1:05 PM
ohiotrader
Jan 31, 2007 1:18 AM
