cooling fans always on
Old Jun 26, 2014 | 9:48 PM
smanmail's Avatar
Default cooling fans always on
When I start the car on a cold engine (overnight) both fans right away come on low speed, air is NOT on....after about 30 seconds they both go full speed and stay there, never shuts off
Temp gauge take 12 minutes to climb to the middle point of the gauge then it stays there all the while both fans are running at full speed...
After I shut the car off both fans go to low speed and run for about 3 minutes before they stop
No error codes, Car has good heat, air is cold when turned on and coolant is full, no leaks , a/c and heat are off when this happens as well as on....any ideas where I should start looking?
Old Jun 26, 2014 | 9:59 PM
sledge.impy's Avatar
What car is this????
DId you just do engine coolant work? Did you bleed your cooling system?
At least you don't have a profile pic already. Thanks.
Old Jun 26, 2014 | 10:18 PM
smanmail's Avatar
sorry, it's an 07 Impala with a 3.5 flex fuel.....just bought the car from a private owner....have all the service records (dealer maintained) and the last time the coolant was flushed filled was at the dealer 4 years ago when they put it on the lot as a certified GM used vehicle...
Old Jun 26, 2014 | 10:53 PM
And these fan speeds are independent of whether or not you have the AC on?
Impala - Chevrolet Forum - Chevy Enthusiasts Forums
Old Jun 27, 2014 | 12:07 AM
smanmail's Avatar
yes, it does not matter weather I have the a/c on or not...they still run fast and wont cycle or turn off unless I turn the car off then they will go low speed after car is off for about 3 minutes and finally shut off
As I said this happens on a cold engine after car sat all night....a/c and heat OFF
Old Jun 29, 2014 | 3:21 PM
smanmail's Avatar
anyone ?
ToolmakerMatt
Uplander
Jan 22, 2026 2:19 PM
damone
May 8, 2021 12:36 PM
nickthevoice
Jan 27, 2019 2:10 PM
SilveradoLS02
Aug 12, 2008 8:45 PM
