cracked flywheel
First, you have to unbolt the trans from the block then diconnect the trans cross member bolts on each side. If there's a trans cooler lines, you have to disconnect them. Then slide the trans back enough to get the converter out of the way so you can unbolt the flexplate. Install new one and put something like blue loctite on the bolts and put it back together.
