cracked flywheel
Old Aug 26, 2014 | 7:07 PM
talgo's Avatar
Default cracked flywheel
Does anyone know the easiest way to r and r a flywheel on 2004 chev. Impala 3800 front wheel dr. Please and thanks talgo
Old Aug 27, 2014 | 9:56 PM
gearbox's Avatar
First, you have to unbolt the trans from the block then diconnect the trans cross member bolts on each side. If there's a trans cooler lines, you have to disconnect them. Then slide the trans back enough to get the converter out of the way so you can unbolt the flexplate. Install new one and put something like blue loctite on the bolts and put it back together.
ncpwrga
Sep 5, 2010 10:25 AM
sbudac
Mar 20, 2007 4:38 PM
WGVette
Sep 27, 2006 2:48 PM
Zeke
Sep 27, 2006 2:32 PM
mrl
Aug 31, 2006 12:23 PM
