Crank/ No Start
Old Mar 15, 2016 | 10:07 AM
DementedMind's Avatar
Exclamation Crank/ No Start
1999 Chevy K1500
My truck cranks but won't start, however some days it fires up with no problem and runs all day with shutting it off and on multiple times. If it sits for 1 day it won't start. After cranking it over you can smell gas as if it is flooded.
Tried
  1. Scanned, showed multiple misfire & MIL light turned off
  2. Changed crank sensor
  3. changed map sensor
  4. changed fuel pump relay - you can hear the fuel pump when you to the key to on.
  5. fuel pressure reads 60psi
The fuel filter is way over due but the pressure isn't being impeded.
I am now leaning towards ignition coil,plugs and wires, ignition modular, coil and coil wire. Maybe camshaft sensor???????????
If any one can please help I would appreciate it, I don't want to keep guessing, luckily the sensors didn't cost much as I have a friend who works at an auto parts store.
Last edited by DementedMind; Mar 15, 2016 at 10:09 AM. Reason: Adding more information.
