Crankshaft Position Sensor 454 7.4
Hi All,
I have a no start/no spark condition:
1998 Chevy K3500 SRW 2Dr 454 7.4L
Replaced Cap/Rotor Plugs Wires Fuel Pump Fuel Pressure Regulator (Fuel Pressure was at 45 now at 55psi)
Looking for the location of the Crankshaft Position Sensor.
Thanks For Your Help
Rob
Rob
Crank sensor is located at the bottom of the timing cover angling toward the passenger side. It's possible you may have a failed ignition coil or a failed ignition coil driver module. If you have access to a scan tool, see if it shows RPM while cranking. If it does, then your crank sensor is good.
