Need help! Engine noise
Old Dec 1, 2017 | 11:28 AM
Ijump03's Avatar
Exclamation Need help! Engine noise
So engine is making a tick/ knock noise, only makes noise when truck is warm, I have replaced lifters thinking it was a bad lifter and no luck, I rand truck hard one night and oil pressure droppped to 2lbs and ever since then noise won’t go away. Motor only has like 16,000 miles on rebuild. Don’t know what do try next any help is appreciated
Old Dec 1, 2017 | 11:49 AM
Oldcat's Avatar
First of all....Make? Model? Engine?
Old Dec 1, 2017 | 1:13 PM
Ijump03's Avatar
97 k2500 suburban with the 454
Ijump03's Avatar
Tried posting the video but it wouldn’t let me
Old Dec 1, 2017 | 1:20 PM
What is the oil pressure now? How long did it stay at 2 lbs? Did you run when it was at 2 lbs?
Old Dec 1, 2017 | 1:27 PM
Ijump03's Avatar
As of now the oil pressure is normal on startup it’s 40+ lbs then one warm drops to about 15lbs. When it oringally happened I ran it for about 15 miles when I Pulled off an off ramp came to a stop and noticed oil pressure was 2lbs.
Old Dec 1, 2017 | 1:57 PM
Oldcat's Avatar
Well if you only have 2 psi oil pressure then either there's a rod/main/cam bearing out or your oil pump is fubar.
Old Dec 1, 2017 | 2:32 PM
Ijump03's Avatar
Ever since that one evening my oil pressure is up to normal operating pressure I’ll try to upload the video again
Old Dec 1, 2017 | 2:40 PM
Ijump03's Avatar
Here is the video
