Cruise Control Problems
Old Jan 9, 2007 | 12:36 AM
amos221's Avatar
Default Cruise Control Problems
I have a 2000 Chev. 3500 with a 454ci engine. I am having problems with the cruise not turning on and working. I have checked the fuse and it is ok. I have tried disconnecting my battery and re-connecting it. The times I have tried using it, it will not activate and when I hold down the accelerate portion of the controls ....Still nothing...can anyone give me some idea's of where to look next......
Old Jan 9, 2007 | 10:39 AM
golfer's Avatar
Default RE: Cruise Control Problems
A simple place to start is check to see if the brake lights come on when you step on the brake pedal. The cruise won't work if there is a problem with the brake pedal switch. If your not having problems with the speedometer then it could be the cruise switch cluster.
Old Jan 10, 2007 | 11:42 AM
amos221's Avatar
Thanks for the help. I will look at the brake lights and let you know ......
pcwilcox
Oct 21, 2013 11:00 AM
liljoe66
Aug 5, 2011 12:44 PM
kbridge234
Sep 4, 2008 10:03 AM
vanhan316
Aug 3, 2007 9:27 PM
lewanddebby
Apr 12, 2006 1:13 PM
