deep pan filter
Old Jan 18, 2011 | 8:30 AM
  #11
therewolf's Avatar
Sorry for the confusion.
The transmission fluid moves at the same, or a slower rate through the
larger filter, which is deeper in the pan.
The way it was explained to me, GM feels the filter depth, (in the pan)and
the slightly larger filter size is going to make it easier for impurities to be more
easily trapped in the filter.
Old Jan 19, 2011 | 2:39 AM
  #12
timelessbeing's Avatar
OK so you're saying that since there's more room in the pan, GM figured they may as well use that space to make a better filter.
Old Jan 20, 2011 | 9:13 AM
  #13
therewolf's Avatar
...while at the same time reaching deeper into our pockets...
Old Jan 20, 2011 | 10:55 AM
  #14
I would suspect that the deep pan also provides additional cooling capacity due to the anticipated use of a 4x4
Old Jan 21, 2011 | 1:01 PM
  #15
therewolf's Avatar
...which would make a lot more sense if it were installed on a lot more 4X4s.
Old Jan 22, 2011 | 3:31 PM
  #16
I have a deep pan on my Astro AWD, and the transmission still gets too hot. I installed a stacked plate cooler to take care of that.
Old Jan 22, 2011 | 10:47 PM
  #17
2wd-K5's Avatar
lol, for dummies: 1 oz if dirt in 12 oz of fluid does more damage than 1 oz of dirt in 16 oz of fluid, the dirt is spread out more (not as concentrated)
not only that but more fluid cools better too
Old Jan 23, 2011 | 6:28 PM
  #18
Uhh yeah I get that, but the whole point of this thread was about the filter.
Old Jan 24, 2011 | 11:16 AM
  #19
2wd-K5's Avatar
thicker filter that sits deeper in the pan, when fluid is low it still takes the fluid, also with the fact that it has more fluid to filter, just go with the big one to be safe
Old Jan 25, 2011 | 10:07 AM
  #20
What do you mean by the fact that it has more fluid to filter? The fluid still moves through the same size opening in the transmission at the same speed. As someone has mentioned, the dirt is more diluted. Can you explain that better?
