Diagnosing the problem with my power windows
Old Jun 16, 2014 | 12:41 PM
OraxThay's Avatar
Default Diagnosing the problem with my power windows
So I've got this '00 Grand Prix GTP (two-door) that I picked up as sort of a project to try to make some money off of. I know it's not a Chevy, but I imagine most GMs use the same or similar power setup. It's nearly finished and the driver's side power window decided to start misbehaving. It gets stuck down; when I hit the button to raise it, it'll go a few inches (so I know it's getting power), but then stop and won't go up or down from there. Sometimes, if I wait a while, I can get it to go up another inch or two, or maybe come back down.
I took the motor out and it still spun (just slowly) when I pushed the button while it was detached from the regulator. I put it back on the regulator to see if I could get it to wind up the window and it went a few inches and stopped again. When I detached the motor again, it wouldn't spin at all anymore.
I figured the motor was going bad, so I picked up another one from the junkyard that seemed to spin much better. It wound the window up all the way (just a little slowly) and back down with no trouble, but when I tried to roll it back up again, it got stuck about halfway up. Now the motor is behaving pretty much the same as the old one.
Before I went through the trouble of exchanging my junkyard motor for another one, I just wanted to ask you guys if this sounds more like the motors were both bad or if maybe there's a problem with the regulator that's put too much strain on the motors and caused them to stop working (I don't know, maybe from overheating or something).
What do you think?
masonmd
Feb 25, 2014 6:53 AM
barnesam
Apr 11, 2012 10:04 PM
spedaleden
Sep 11, 2011 2:03 PM
countryboy92
May 20, 2011 9:55 PM
daddytaz
Jan 9, 2011 10:29 PM
