Distributor Help
Old Jun 23, 2021 | 9:34 PM
Curtis Brown's Avatar
Default Distributor Help
Distributor Help
Hello Is this somewhat correct? 97 chevy v8 350 5.7L suburban
Old Jun 24, 2021 | 1:41 PM
oilcanhenry's Avatar
Looks OK to me.
Old Jun 25, 2021 | 11:48 AM
Looks OK to me.
ok Thanks for your reply...put everything back on...fired it up 1st read -25 degrees out...adjusted the distributor only was able to get it to -6 at times -2. Turned it as far as it will go. What could I be doing wrong?
Old Jun 25, 2021 | 1:36 PM
It's hard to tell from the photo. With the timing marls lined up at TDC, the rotor should point to #1 cylinder. Did you have the distributor out? You might be 1 tooth off on the distributor installation.
Hiattech
Feb 10, 2020 10:14 AM
StudeTom
Jun 7, 2016 8:34 PM
VerduGMC
Mar 10, 2014 7:58 PM
metalman1232
Feb 24, 2014 12:16 AM
Er Au
Jul 10, 2012 7:17 PM
