Do i need to have my 454 line bored again?
Old Jan 5, 2022 | 6:42 PM
DEJAVU's Avatar
Default Do i need to have my 454 line bored again?
I purchased a fresh 454 block that had 4 bolt caps added and aline bored ( caps attached with factory bolts). I wanted to add main studs to attach the caps and a local machine shop told me if i did the 454 would have to be aline bored again ! Now i have added studs to many bbc unbored and fresh aline bored, after machine work is done and i have never had a problem ! So has anybody else heard this ?? Thanks tom
Old Feb 10, 2022 | 8:11 PM
The Heater's Avatar
Hello:
I concur with them. Once they mount the studs they must be torqued into the block and this may cause some distortion that affects the alignment of the passages for the crankshaft journals. It is from the fact you are installing studs. It can't be that expensive to do that second line bore and it is peace of mind. Are you going to do all that work assembling it just to find out they were right maybe 20,000 miles later? I would get the second line bore. If you don't want it then use bolts.
ljpolasek
Dec 22, 2013 10:17 AM
cdaeuros
Nov 13, 2013 9:43 PM
shipma2
Feb 13, 2012 5:18 PM
800bomer
Aug 15, 2010 5:08 PM
