Doing major tuneup/preventative maintenance to 1995 Chevrolet G20 Van
I just bought a 1995 Chevy G20 with 98k miles. I'm going to convert it into a full-time camper and I'm looking to do a major tuneup/overhaul of it.I am mechanically inclined so I would be doing all the work myself. I don't know if I'm going overboard but here is what I was thinking of replacing:
Please let me know if there's anything I missed. Is this appropriate or is any of this overboard/unnecessary? The only reason I want to do all of this now is to mitigate the risk of ending up on the side of the road with the only vehicle I have and that is my home. All the parts I use will be OEM or high performance parts, nothing aftermarket. Any help is appreciated, thank you!
- All brake components, change brake fluid
- Leaf springs, shocks, struts, bushings, etc.
- Battery (has a little trouble cranking)
- Distributor cap, rotor, spark plugs, spark plug wires
- Water Pump
- Thermostat
- Drive Belt
- Fuel Pump w/ housing assembly
- Fuel Filter
- Air filter
- PCV filter
- Starter
- Alternator
- Flush and refill coolant system
- Change transmission fluid
- Change differential fluid
- Change engine oil
- Change power steering fluid
