Easy way to check AC compressor? '03 Silverado
Old Jun 2, 2021 | 11:04 PM
rpeters549's Avatar
Default Easy way to check AC compressor? '03 Silverado
So I got a recharge kit for the AC since it wasn't blowing cold. The guage indictated full. Light comes on on the dash button, fuse and relay are good. I notice the compressor isn't turning on. Can I check to see if it's a wire break or should I assume a bad compressor?
2003 Silverado 1500 Z71 with the 5.3.
Thanks!
Old Jun 3, 2021 | 7:03 AM
Check the wire going to the clutch on the compressor for voltage. If there is voltage then the clutch is bad and the compressor may or may not be good. If there is no voltage check the pressure switch on the accumulator. Also check for a broken wire.
Old Jun 3, 2021 | 7:57 AM
rpeters549's Avatar
I will do that, thanks. I have owned very few vehicles with AC so not familiar with them, but I understand basics. I will check for voltage with KO/EO for safety of course, dash switch on . At least I assume that will do it. I had no idea the clutch and compressor could be separated.
Old Jun 3, 2021 | 11:34 AM
I
They can be separated but you have to be careful not to damage the seals. there is a special tool to do the job and it should be used.
Old Jun 3, 2021 | 12:38 PM
rpeters549's Avatar
Thanks! I will be sure to borrow the tool if I go that route. If it's fairly inexpensive I might just give it a shot. Of course checking the wire for power is free.
falconbrother
Feb 10, 2017 10:13 PM
bnbelectronics
Jun 12, 2016 3:13 PM
Tom Cullen
Jul 21, 2011 12:20 PM
raymontx
Aug 5, 2010 7:02 PM
sgp7679
Jul 31, 2010 4:23 PM
