ecm questions
Old Oct 17, 2011 | 8:51 PM
  #11
maxxman04's Avatar
sounds a little odd, but put the 305 injectors in, unless that's what you are using already. it kinda goes against logic and all.
Old Oct 17, 2011 | 8:58 PM
  #12
t-roy383's Avatar
tried both sets of injectors, same thing. yeah it sounds odd. cant get the guy that did my chip to check and see if he did something wrong. (everybody makes mistakes). the calpac number in the 7747 shows to be for the camaro ecm, but it dosnt have a removable chip, could that be the dif? thanks
Old Oct 17, 2011 | 9:04 PM
  #13
maxxman04's Avatar
its something in the fuel and spark delivery obviously. and yea, def possible the chip wasn't programmed right, or something has happened to it. with ecm, timing advance is done electronically, but you do have a 4 degree either way tolerance. i'm not convinced it's all timing tho. something is not telling injectors to spray more.
Old Oct 17, 2011 | 9:09 PM
  #14
t-roy383's Avatar
the spray looks good even when it hits the dead spot, so it prob in the spark at that certain point
Old Oct 17, 2011 | 9:20 PM
  #15
maxxman04's Avatar
i'm still inclined to think in the fuel. if it was spark, it wouldn't necessarily have a dead spot. it might sputter, but still go. the fact that the stock ecm lets it accelerate just fine, that leads me to think the chip or ecm chip is in is messed up.
Old Oct 19, 2011 | 10:05 AM
  #16
t-roy383's Avatar
im not convinced that these ecms are interchangable, they both run totally dif. unless the esc, knock sensor, map are dif. they show bif part numbers from a 5.0 to a 4.3 and a 5.7 which show the same. could that be a problem? thanks, t-roy
87camaro
Apr 16, 2020 1:55 AM
fawvers
Jan 7, 2013 1:02 PM
fastblueheeler
Aug 12, 2006 2:53 AM
Spudweiser
Aug 8, 2006 12:33 AM
MotorMadness
Jul 25, 2006 4:00 AM
