Ecu
Old Jan 12, 2017 | 7:51 PM
Michael Lange's Avatar
Default Ecu
i have a 2014 Chevy Silverado 4x4, it's saying engine power reduced service stabiltrack ive fixed the problem but the truck is not resetting nor will the truck start on engine power reduced is there any way on the newer Silverado to reset the PCM ECU OR ECM? I know on older model Silverados it was nothing more than disconnect the battery for 10-15 minutes and the ecu would reset itself I tried this method and am still coming up short any suggestions?
Old Jan 12, 2017 | 11:14 PM
clear the dtc with a scan tool. disconnecting the battery does not clear faults as
codes are not stored in volatile memory.
if the faults do not clear with a scan tool, the problem is not fixed.
