egr testing?
Old Feb 11, 2010 | 4:25 PM
maxxman04's Avatar
Default egr testing?
98 vortec 350 VIN "R" motor. is there ways to test the egr valve, or symptoms that it might be dead or dying?
Old Feb 11, 2010 | 4:48 PM
maxxman04's Avatar
thanks 1Gary. it does idle a bit rough, not horrid tho. runs great otherwise. could egr issues kick a misfire code?
Old Feb 11, 2010 | 5:30 PM
maxxman04's Avatar
took egr off, looks pretty clean. the pintle moves freely, very minor carbon. did notice there are three screws but ya gotta go thru the canister. is that possible to disassemble the whole thing without breaking it? also, while idling, i pulled the connector off, no change in rpm. is that normal?
Old Feb 11, 2010 | 6:06 PM
maxxman04's Avatar
gathered some data from my scanner. LT fuel trim bank 2 is -18 at idle, -11.7 at 2000 rpm. bank 1 3.1 at idle, hovers -2 to 2 at 2000 rpm. seems like all 4 02 sensors are ok, at least according to the data, so i'm suspecting 1 or more injectors may be done. still kicks p0305 at me, even after resetting. i assume that even one leaky injector would cause my trim levels to be negative on that side. or am i off?
fjdavid
Jan 26, 2008 2:41 PM
jcarter
Sep 26, 2007 5:49 PM
richrd
Sep 17, 2007 2:00 PM
pursang
Dec 27, 2005 12:34 PM
