Notices
engine stop while driving !
Old October 26th, 2009, 8:54 PM
FRENCHEVY's Avatar
Default engine stop while driving !
my 1995 tahoe, 350 tbi engine shut down last saturday while driving . I checked all fuses , ok , then i thought it was the fuel pump again , but I believe it work cause I can heard it when I turn on the ignition key and if I try to start the engine , I got gas in the tbi , but it seem to me like there s no spark , so I replace distributor cap and rotor , which was in bad shape , but still nothing , so I'm stuck trying to figure it out , any help will be welcome . could it be the ignition coil ? how can I check if there is voltage coming out of it ? can the computer be bad too .
Old October 26th, 2009, 8:56 PM
Professional Mechanic
MDTAHOE's Avatar
Could be the ignition coil and or the module. Ignition module failure is fairly common.
Old October 26th, 2009, 9:04 PM
devo098's Avatar
yah usually if the truck just shuts off, no sputtering or lack of power, but just shuts down, it is the ignition module. its Really easy to change and not terribly expensive.
Old October 27th, 2009, 9:58 AM
therewolf's Avatar
Don't forget to put the dielectric grease on the metal plate on the bottom of the module before you install it in the distributor.
Old October 27th, 2009, 8:34 PM
FRENCHEVY's Avatar
yes it was the ignition module , thank you all . I went to get one this morning , install it this evening and my Tahoe is running again , great cause I don't think I could get rid of it .
olderndirt
July 3rd, 2014 10:13 PM
oldmanROn
Uplander
June 18th, 2014 10:31 AM
99SuburbanTX
September 9th, 2012 5:09 PM
dkalleck
October 3rd, 2011 5:17 PM
metalmike187
December 19th, 2010 11:22 AM
Quick Reply: engine stop while driving !
