Engine swap
Old Oct 24, 2024 | 6:24 PM
ttcrash199980@gmail.com's Avatar
Default Engine swap
Ok new to group, need help bad. Ill start from the beginning. Motor in my 2014 chevy 5.3 started making a squealing noise, though it was belt, took off all belts buddy says i spun a main bearing. Got used engine, installed and now no run. My code scanner said p127c fuel pressure sensor along with several other codes all dealing with fuel. Found out from 14-16 gm used a 4 pin sensor, 17 up used a 3 pin connector, wiring harness for the sensor and drivers injectors was bad on old motor so i ordered a new 1. Put in new 4 pin fps and harness and still no run. I have checked all grounds, both plug ins on back of intake (they r in the right plug i checked colored wires to make sure), changed all sensors on engine. Buddy came today with snap on scanner. Cleared all stored codes, tried to crank and the only code we got said alternator not charging. Could that b my whole problem. Ive been working since last friday to make it run and im out of options. Plz someone help
emh2003
Apr 21, 2019 12:41 PM
99twoDoor
Sep 21, 2017 7:09 PM
Indrid
Feb 27, 2014 8:00 PM
fish2222
Jan 11, 2012 7:05 AM
jophilpott
May 14, 2008 9:13 PM
