Failed emmisions because of this MIL issue
Old Feb 2, 2020 | 5:11 PM
shep28's Avatar
Default Failed emmisions because of this MIL issue
Reason for failure:
MIL Engine Off
Passed MIL Engine On test.
No codes when I used my scan tool.
What could cause this issue?
2000 Silverado 2500 6.0
Old Feb 3, 2020 | 12:44 AM
oilcanhenry's Avatar
Originally Posted by shep28
Reason for failure:
MIL Engine Off
Try cleaning the MAF. Lots of times its dirty or bad but wont show a code.
Old Feb 3, 2020 | 1:21 AM
are u saying the check engine light bulb check failed?
Old Feb 3, 2020 | 5:24 AM
shep28's Avatar
I assume that is what it means. It failed when was key turned off, but the light worked when on. Seems like if the bulb needed to be replaced that it would not work either time. That test was a visual test.
Old Feb 3, 2020 | 1:00 PM
not sure what you are describing.
proper operation is: the mil light should light up at key on, engine off, then go off with the engine running if no dtc are set.
if its not illuminating at key on the led in the cluster may be bad. someone with a good scan tool can do a bulb verifcation check.
042500HD
Jan 12, 2016 10:17 PM
debowens
Aug 16, 2015 10:26 AM
RitualJman
Nov 20, 2012 4:27 PM
jackcountytruck
Apr 7, 2011 8:56 AM
apolahar08
Mar 7, 2009 2:49 PM
