Fan doesn't work on Tahoe
Old Jan 7, 2016 | 8:15 PM
Buckshot00's Avatar
Default Fan doesn't work on Tahoe
My ac / heat blower fan does not work. Front or back. Help.
Old Jan 8, 2016 | 7:27 PM
cleveland63b's Avatar
what vehicle? any codes? they don't work at all or in certain speeds?
Old Jan 8, 2016 | 7:45 PM
Buckshot00's Avatar
2003 Tahoe. No codes. Do not work at any speed.
Old Jan 9, 2016 | 8:27 AM
chevy55's Avatar
check all your fuses in the under hood fuse box,left driver side fuse panel and also the right side fuse panel inside the vehicle.if you haven,t checked your fuses check those first.if you lose power to one side of the hvac control panel it won,t power the front or rear heat/ac system.
Old Jan 13, 2016 | 3:17 AM
gearbox's Avatar
Start with fuses, switch and wiring.
Old Jan 13, 2016 | 6:26 AM
Buckshot00's Avatar
Thanks.
Old Jan 13, 2016 | 2:38 PM
Buckshot00's Avatar
Fuses are good.
