Fault code P0053
Old May 1, 2020 | 1:55 AM
prostreetpop's Avatar
Default Fault code P0053
Hi all.
I own a 2005 Silverado 1500 5.3 here in England so not many people to turn to for help.
I keep getting a fault code P0053 ( bank 1 sensor 1 ) come up
I’ve changed the O2 sensors and checked the voltage to the heater side, which is ok, but still keep getting the fault code appear.
Would it possible that the fuel press regulator is faulty causing this or am I looking in the wrong place.
Thanks in advance for any advice
Mark.
Old May 1, 2020 | 7:01 AM
Check the wiring to the O2 sensor for any damage. Also check for exhaust or vacuum leaks. The fuel pressure regulator is a possibility.
Ianmac
1988 - 1998 (GMT400)
21
Mar 22, 2020 11:34 AM
Kamelred408
Jan 15, 2020 4:02 PM
rykanotari@gmail.com
Dec 1, 2019 8:00 PM
realtruck
Nov 24, 2006 11:53 AM
