Fuel pressure only at 10psi
Old Apr 9, 2018 | 2:44 PM
Mikemcc's Avatar
Default Fuel pressure only at 10psi
I checked the fuel lines, changed the filter and fuel pump and still only getting 10 psi. Spark is not a issue but will not turn over thinking it does not have gas to it. Someone please help Im pulling all my hair out
Old Apr 9, 2018 | 3:11 PM
kevinkpk's Avatar
You need to post type, year vehicle you have. The only thing I can assume is that it is an electric fuel pump.
Old Apr 10, 2018 | 8:04 AM
Mikemcc's Avatar
1998 chevy 2500. I changed fuel filter and fuel pump. I check the fuel line and it seemed to be clear. Do you think the fuel return line can be a issue?
Old Apr 10, 2018 | 11:41 AM
kevinkpk's Avatar
I'd suggest pull the fuel line, and stick it in a 5 gallon bucket and see what comes out. Could be obstructed with rust. You can do the same with the return line if you think it might be an issue.
