Fuel pressure regulator and Schrader valve
Old Mar 8, 2025 | 6:31 AM
Baspinall's Avatar
Default Fuel pressure regulator and Schrader valve
Can someone show me the location of the fuel pressure regulator on a 2015 Silverado 5.3.
Also trying to find the schrader valve to hook a fuel pressure gauge to. This truck makes me feel like I have never worked on a vehicle some times.
My truck sits for a long time because I use my work truck. Last couple times I have started it, it has a sluggish start. Almost like a battery problem. Batter has correct voltage. I have tried the priming the fuel pump idea by turning the key to the ON position for a few seconds. Seems to be intermittent. Took it for a ride. Sat for about an hour and it almost didn't start again.
Anyway, I would like to see if I see any fuel at the regulator when I pull the hose as well as check to see if it is holding pressure or if it drops after a while.
TIA
Spechul ed
May 20, 2022 3:38 PM
Spechul ed
May 20, 2022 3:37 PM
Yellowrocket
Jun 19, 2021 11:38 PM
markwemple
Jul 31, 2014 11:20 AM
crbav8r
Sep 28, 2010 6:37 PM
