fuel pressure, tbi questions
Old Sep 26, 2011 | 8:14 PM
t-roy383's Avatar
Default fuel pressure, tbi questions
i have a 91 camaro rs with a 383 stroker. it has a .495 lift cam, 305 heads, stock intake, 350 throttle body. i had a custom chip made for this set up. im running rich but have low fuel pressure. the fuel pump itself shows 10lbs of pressure, when running it also shows 10lbs. i have rebuilt the throttle body. there are no trouble codes showing. any suggestions? thanks
Old Sep 27, 2011 | 5:42 PM
t-roy383's Avatar
ok, got the fuel pressure up to 14lbs, but i am still running rich and still have a dead spot with a quick acceleration, a slow acceration is smooth. any ideas?
Old Sep 28, 2011 | 8:21 AM
T.Neff's Avatar
Banned
Who did the chip burn??.When you say your rich...........your not tell us about a fuel map at what RPM.Remember that ECM also involves ignition timing and advance.I'll get you the name of the company that eliminates chips completely so you can tune live.But they are costing about $490.00.
Well here it is in any case:
http://www.dynamicefi.com/
Old Sep 28, 2011 | 8:36 AM
jknight12's Avatar
with a dead spot in quick acceleration.. check the tps ( throttle position sensor ) on the side of the throttle body.. sounds like simalar problem i had with my chev 350..
hope this helps
bpo
Jun 16, 2014 5:55 AM
chrisz71
Jun 10, 2013 10:11 PM
chrisz71
Jun 10, 2013 9:02 PM
richardbentz
Jan 30, 2010 12:21 PM
Focalor
Apr 12, 2008 9:43 AM
