Fuel Pump Relay Burning
Old Sep 13, 2010 | 10:50 PM
elsworth's Avatar
Default Fuel Pump Relay Burning
Ok - so spent the last two evenings searching throughout this site researching for clues. We are completely stumped. 1995 Blazer (Jimmy) We have purchased multiple fuel pump relays that keep burning up (same terminal every time). We replace the relay and get about three months (now less) out of it before replacing again. Car dies intermittently or drops off while driving. Here is what has been done - in this order: Ignition switch, Fuel pump (entire kit), relay, relay, relay, fuel pump (entire kit), relay, relay, you get the picture. In addition, ran seperate ground from fuel pump to confirm proper grounding, verified fuel pressure (60psi), voltage (12+V), and searching for other areas to look at before tearing apart.
Old Sep 13, 2010 | 11:25 PM
MDTAHOE's Avatar
Professional Mechanic
replace the fuel pump relay socket. You will need to make it external from the relay box. I have seen this a few times. Your other option is to replace the relay box.
Old Sep 13, 2010 | 11:30 PM
elsworth's Avatar
Thank you! We will give that a try. I will post how it works out.
brerobx
14
Jun 26, 2021 4:36 PM
BRB
Dec 28, 2012 8:34 PM
hunter10220
May 18, 2011 8:37 PM
mikee
Aug 26, 2007 10:38 PM
oneflatoniakid
Jun 18, 2007 10:30 AM
